meshing 3 connected volumes with gambit
Old   July 19, 2006, 11:54
Default meshing 3 connected volumes with gambit
Miguel
Hello dear colleages! I will greatly appreciate any help on meshing with Gambit.
I want to have a splitted and connected/bidierctional three volumes.
The first volume (the Gas diffusion layer)is 45 X 45 X 0.2 units, the second (Bipolar plate) is 55 X 55 X 1 units, the third one (the flowfield) is 1 unit deepnes and 1 unit breith channel. This flowfield is inside the second volume.
All are concentric and have contact.
I cannot get to mesh the second volume with hexahedral cells. Just tetrahedral (wich are useless due to our limited PC capacity of 4 GB RAM) The failure i get when using hexahedral is a logical cube for meshing is not found.
I have tried to mesh all edeges, faces and then volumes, but at the end, even when I have simetrically meshed all the faces, I donīt get the volume meshed.
I will greatly appreciate any suggestions!
Miguel
Old   July 20, 2006, 06:50
Default Re: meshing 3 connected volumes with gambit
RoM
Can you post a picture of your domain? A hardcopy with "connectivity option" turned on would be best to understand you problem better.
RoM
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 prashanthreddyh ANSYS Meshing & Geometry 1 December 20, 2011 01:35
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 21, 2006 00:31
Meshing two volumes Vidya Raja FLUENT 1 October 5, 2005 03:46
GAMBIT crashes during meshing Nick FLUENT 6 October 28, 2004 04:02
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 10:22
