user_sub FIDAP doesnt work
Old   July 18, 2006, 14:56
Default user_sub FIDAP doesnt work
semetay
Hello everyone,
I created a user subroutine and trying to compile a new executable by using user_sub batch file provided with Fidap. I am using it like this;
user_sub fidap myfidap fidap_user
and getting the following;
USER_SUB: INCORPORATE A USER SUBROUTINE INTO FIDAP
THE FOLLOWING PARAMETERS WERE SPECIFIED:
PROGRAM NAME: FIDAP
NEW EXECUTABLE NAME: myfidap.EXE
USER SUBROUTINE FILE NAME: fidap_user.F ************************************************** *****************
BEGINNING REBUILD OF FIDAP AT Tue Jul 18 14:38:13 2006 -----------------------------
'ifort' is not recognized as an internal or external command, operable program or batch file. LINK : fatal error LNK1181: cannot open input file "fidap_user.obj" ---------------------------- FINISHED REBUILDING FIDAP AT Tue Jul 18 14:38:14 2006
I have compaq visual fortran 6.6c installed. Anyone had a problem like this? I will appreciate any help on this.
Thanks,
semetay
Old   July 22, 2006, 08:32
Default Re: user_sub FIDAP doesnt work
ztdep
Hi: have you resolved the prolbem? I have met the similar problem as you!
Old   July 22, 2006, 11:30
semetay
hello,
Not entirely. I installed microsoft visual.net and then intel fortran compiler. then i started command prompt from visual.net tools. I run user_sub command and ifort and link commands inside the user_sub worked.
Now the compiler works but I am getting other errors like some of the lib files could not be found. I found and copied those lib files to the working directory, now some other errors (these I didnt understand exactly).
I am still working on it but this compiling thing doesnt have a standart solution.
are you having the exact same problem??
semetay
Old   July 22, 2006, 20:51
ztdep
I installed the compare visual fortran 6.5 , the error is just the same as you "errors like some of the lib files could not be found", I have also run it in the linux, only one of it can compiled sucessfully, the oter also give the same error as the above! I have no points about it!
Please I need your help with FIDAP hussam66 FLUENT 1 October 11, 2016 16:07
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
Fidap to Fluent Ravi FLUENT 3 July 10, 2008 14:31
Radial jet with free surface using FIDAP Dr. Ahmed Hassaneen Main CFD Forum 0 October 28, 1999 14:20
Fluent vs. Fidap Lisa Eastep Main CFD Forum 1 July 16, 1999 01:13
