VOF simulation free surface caused by gas inject
Old   July 17, 2006, 03:19
Default VOF simulation free surface caused by gas inject
rensb
hi,my friends
i have read a article about the vof simualtion, the case is there is a ladle full of water, and behind there is xoygen lance ,the problem is simualtion the free surface caused by oxygen lance injection. how to set the interface of gas and liquid .
thank you for your advice
Old   July 18, 2006, 10:06
Default Re: VOF simulation free surface caused by gas inje
Aniss
i have the same probleme between vap/liq interface in bubble cavitation collapse?!!!!
Old   July 19, 2006, 17:27
J.Gimbun
I dont really understand what is your problem, but if you wana simulate a gas entrainment on the liquid surface just use initialise patch. Good luck.
Old   July 19, 2006, 20:16
rensb
the problem is in the clinder ladle full of water(half height),and above the water ,in the center of the ladle there lied an laval nozzle which spray oxygen and so on, the spray gas will inject into water and caused the water move, how to simulate this case the free surface is cared for ,and after patch ,it is difficult to converge,how to solve. thank your advice.
Old   July 20, 2006, 05:45
J.Gimbun
Definietly some difficulty in getting convergence. In the initial stage try small time step and few iteration/time step. Later on adjust it to be much higher and more time step to get convergence every time step.
VOF free surface vortex simulation mahdiii FLUENT 3 May 14, 2013 16:33
free surface of VOF and melting model? wanghong FLUENT 3 March 13, 2006 10:57
define a layer at the free surface in VOF model UDF for normal distance at free surface in VOF mo FLUENT 0 March 20, 2005 07:20
turbulence simulation and free surface vineet Main CFD Forum 3 September 23, 2001 12:25
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
