Free Surface Jet Impingement
Old   July 14, 2006, 04:45
Default Free Surface Jet Impingement
John
Hi
I am modelling Jet impingement onto a flat plate, but I am having difficulty establishing the correct boundary conditions.
I have created a 2D VOF axi-symmetric model, with air as the primary phase and oil as the secondary phase, pressure inlet and pressure outlet.
I initialise and then patch oil (Volume fraction 1) into the required region then run the itteration using a time step of 1E-8 (other wise floating point error occurs). After a short while i display the contour plot, but it appears as though oil is entering through the outlet.
I think I have made an error in defining the boundary conditions/patching in the oil. can anyone provide any help with this matter?
Thank you in advance
John
free surface display carno Siemens 4 October 7, 2005 02:03
free surface display novice Siemens 5 August 4, 2004 02:07
Equilibrium of a free surface under surface tensio Ryan Main CFD Forum 1 August 7, 2001 17:14
Velocity on Free Surface Boundary Lin F.F Main CFD Forum 3 August 4, 2001 12:30
Modeling Free Surface Flows Elliot Schwartz Main CFD Forum 5 August 25, 1998 22:03
