Divergence in AMG solver: species-4
Old   July 13, 2006, 10:58
Default Divergence in AMG solver: species-4
BillChen
I'm currently simulating gas species reactions inside a chemical vapour deposition chamber. Some of the reactions I have modelled diverges. All the material properties I defined are based on ideal gas law and kinetic theory. The rate laws are not Arrhenius relation, so I have defined UDF for the reaction rates. The problem I have is that, whenever I run the simulation, the console shows me warning message about mass diffusivity being zero, and for several seconds, the simulation crashes with a divergence error. I have tried everything including decrease the reaction rate law by 1000000 times, only then the simulation converges, but that's not right. I would hope that someone know to solve or at least has seen this problem before could help me figure out what's wrong!
Old   July 15, 2006, 02:14
Default Re: Divergence in AMG solver: species-4
sree_rahul
hi..chen
i faced the similar problem" divergence in AMG solver: species 2" when i am running methane-air combustion problem. since i didn't write any udf i simply changed relaxation parameter from 1 to 0.8 or 0.7 for that corresponding species 2.. it worked... i think your problem is much more complex than this .. try once like this..good luck.
Divergence Detected in AMG solver- Species 0 elmcmaster FLUENT 34 February 15, 2023 11:08
Divergence in AMG solver! marina FLUENT 20 August 1, 2020 12:30
species transport: amg divergence luke FLUENT 2 November 22, 2015 15:25
Divergence Detected in AMG solver- Species 0 elmcmaster ANSYS 0 July 9, 2010 07:24
divergence in AMG solver Merinadica FLUENT 0 December 5, 2006 09:17
