can you confirm
Old   July 12, 2006, 23:40
Default can you confirm
greg
hi. can you confirm that species in mixture are ordered from 0 , 1, 2, 3 etc.?? Has species in single phase number 0 or "-1"?? And in VOF model primary phase is 2, seconday is 3 and 1 is what? whole mixture?? Than what is 0 if there is?? I know that single and primary phase numbers I can find in phase panel but what abouth the rest I mentioned above? Thank you
Old   July 13, 2006, 01:51
Default Re: can you confirm
RoM
The numeration of species in a mixture starts with zero for single phase flows. I can confirm it for species tranpsort model (single phase) and the non premixed combustion model. I had not the time to test it in multiphase but i dont see why it should be different from single phase flows.
The phase index from the phase panel is used in the Get_Domain() macro to get the phase domain pointer. If you use Get_Domain(1) in a multiphase flow you will get the mixture domain. Please note that in this case the "mixture" is the phasemixture and not a species mixture. If you use the Get_Domain() macro to retrieve the phase domain pointer, the zero index is not used.
If you use the DOMAIN_SUB_DOMAIN macro to get the phase domain pointer things are different. In this case the primary phase index is zero, the first secondary phase is 1 and so on (just subtract 2 from the index shown in the phase panel).
RoM
Old   July 14, 2006, 10:32
greg
Thank you very much
Please confirm, if this is a bug or a typo N. A. OpenFOAM 0 August 18, 2010 13:51
OpenDx and Debian testing ie lenny AMD64 msrinath80 OpenFOAM Post-Processing 0 July 27, 2008 18:27
Please confirm current InterDvMFoam capabilities in 2D adona058 OpenFOAM Running, Solving & CFD 0 July 25, 2008 15:22
How to confirm that OpenFoam runs in 64 bit jdk OpenFOAM Running, Solving & CFD 2 February 5, 2008 05:55
Please help!! Need to Confirm something -Transient Julie FLUENT 5 September 5, 2002 13:45
