Is the drag coefficient right?
Old   July 12, 2006, 23:14
Default Is the drag coefficient right?
mimibenben
How to know you get the right number of drag coefficient,lift coefficient and moment coefficient?
Or generally,how big are these coefficients?
and THANKS A LOT!
Old   July 13, 2006, 03:22
Default Re: Is the drag coefficient right?
ramp
Compare the values you obtain with some experimental or computational results available in the literature.
well, the drag values depends on the flow type and schematics... for instance.. at low Re flow (creeping flows), the value may be of the order of 1000 but at high Re it may of the order of 1....
Old   July 13, 2006, 23:08
mimibenben
My question:
3D missile,Mach=0.6,coupled,explicit,steady,
pressure-far-field:guage pressure=101000,
pressure-outlet:guage pressure=101000,
my caculation results:
drag coefficient = 3.335276 lift coefficient = 0.001501 moment coefficient = 0.001899
and I'm not sure if the results are right,could you help me?
Thanks a lot!!!!!
Old   July 13, 2006, 23:14
mimibenben
By the way,
My referencearea=PI*missileRadius^2=8.5609608
referencelength=missilelength=51.304
Drag Coefficient Convergence Problem John FLUENT 18 June 24, 2023 10:22
drag coefficient in ansys fluent 12.0 krishna FLUENT 19 April 12, 2018 01:49
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 07:24
Drag coefficient for parcels in dieselFoam sebastian_vogl OpenFOAM Running, Solving & CFD 5 December 31, 2008 13:19
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
