Tangential velocity
Old   July 12, 2006, 10:35
Default Tangential velocity
Jan
How does fluent calculate the Tangential Velocity? I mean is the SQRT(Vx^2 + Vy^2)? or does it use another way? kind regards, Jan
Old   July 12, 2006, 12:11
Default Re: Tangential velocity
Jason
That would give you the magnitude in the X Y plane... assuming that your axis is the Z-axis, this would be the combination of the Radial and Tangential components...
Again, assuming the Z-axis as your axis of rotation, then Tangential would be Vx*cos(theta)-Vy*sin(theta) and Radial would be Vx*sin(theta)+Vy*cos(theta).
You have to tell Fluent what your reference axis is. This is in the Define->Boundary Conditions... Select the Fluid volume... here you can define the axis origin and direction. The equations will change depending on the location and direction of the axis, so what I gave above is stricly for an axis of rotation coincident with the Z-Axis.
Hope this helps, and good luck, Jason
Old   August 1, 2018, 17:06
vaqif
vaqif is on a distinguished road
hi,
I am modeling a fan by using Fluent fan boundary condition. Also, I have defined polynomial tangential velocity in swirl specification. After iterating, I can not get the same profile that I defined first. Even, when I give constant tangential velocity magnitude, I can not obtain the same velocity when I draw the xy plot.
I am wondering maybe my definition from tangential velocity is different than fluent!
could you help me
vaqif is offline   Reply With Quote
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 20:08
how to compute relative velocity from absolute? spk Main CFD Forum 3 July 9, 2010 09:42
Cyclone Tangential Velocity ... Abdul FLUENT 2 August 13, 2008 01:07
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
Radial and tangential velocity Antonio Mileo FLUENT 2 February 16, 2001 02:41
