radial inflow turbine rotor periodicity problem
Old   July 11, 2006, 21:35
Default radial inflow turbine rotor periodicity problem
Nanda
hi, i've modelled a flow passage of a radial inflow turbine consisting 15 blades.for modelling purpose i made use of the periodicity of the flow and modelled a single passage.however when i displayed the result by taking 0.5 constant grid spanwise location and displayed the 360 degrees view, the default number of repeats was 17 which is not consistent with my model.any suggestion of what am i doing wrong? i've already checked and rechecked my model in gambit.
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
Calculating lift force of a wind turbine blade problem LittleBart CFX 4 June 29, 2011 03:33
Convergence of Radial Turbine Simulation Hugh CFX 10 June 30, 2010 09:08
radial turbine flow analysis ME Siemens 1 August 16, 2007 04:06
radial turbine flow analysis ME FLUENT 0 July 2, 2007 10:18
