FIDAP and temperature dependent mat properties
Old   July 11, 2006, 14:45
Default FIDAP and temperature dependent mat properties
semetay
I am running a 2D problem which has solid and fluid elements. Fluid has a free surface. This is a simple represantation of a laser welding problem.
I can see the temperature contours and the velocity fields in the melt pool if I use constant material properties. When I try to use temperature dependent mat properties (visc(curve=2) etc.), it doesnt work. In the Fipost it says only mesh could be shown.
I am new to FIDAP so any help will be appreciated.
Regards,
Cumali
FIDAP and temp dependent mat properties PLS HELP!! SEMETAY FLUENT 1 July 14, 2006 03:04
Phase Change+strong Marangoni, FIDAP - need a help Vitaliy Pavlyk FLUENT 0 July 31, 2001 06:12
FIDAP - Lubrication Barman Tambunan FLUENT 0 March 25, 2001 20:43
Variable Density - Free Surface with FIDAP Vitaliy Pavlyk FLUENT 7 May 2, 2000 16:56
