Fluent Convergence Problems
Old   July 13, 2006, 15:28
Default Re: Fluent Convergence Problems
  #21
Jason
For the mesh pics, I'm trying to see why you have so many elements in the cylinders (where the flow should be pretty straight forward) and so few near the valve (where the flow will be pretty complex if I remember your valve correctly). So I'm thinking the TGrid pics would be good. Anything that gives me a reasonable idea of what your mesh is like.
Send them to my yahoo e-mail... (I'm still using jason_at_bae). I should be able to check it later tonight.
Thanks, Jason
Old   July 13, 2006, 16:02
  #22
Vidya
Jason,
I just sent you the e-mail.
Thanks, Vidya
Old   July 17, 2006, 09:02
  #23
Vidya
Hi Jason,
I'm still getting the floating point error in my unsteady case and it looks like this time too the computation will go on forever. The residual for continuity is rising steeply and now after 154 iterations has reached 3e+17 and is continuing to increase. hat may be the cause for this?
Thanks, Vidya
Old   November 5, 2012, 09:09
Question Error: Divergence detected in AMG solver: x-momentum
  #24
Jaiganesh S
Jaiganesh S is on a distinguished road
Hi everyone,
I am doing Aeroacoustic analysis on aircraft wing using Ansys fluent. After 53 iterations, it getting error. I mentioned that error below.
Error: Divergence detected in AMG solver: x-momentum.
I have described about my case below.
Pressure based, Transient.
LES Model.
Velocity Inlet , pressure outlet.
Scheme- PISO, neighbor correction - 1, Pressure - standard, momentum - Bounded central differencing, Transient formulation- First order Implicit, non iterative time advancement.
URF for Pressure - 0.001, for Momentum - 0.004.
And also I used Outflow as outlet instead of Pressure outlet. I changed neighbour correction & under relaxation factor. These Changes are not working.
Grid quality details:
Max. cell squish= 9.23091e-001.
Max. aspect ratio = 3.22832e+002.
Kindly help me to solve this problem. I am waiting for your kind response.
Thank you.
Jaiganesh S is offline   Reply With Quote
Old   January 1, 2016, 14:01
Hitesh
hiteshlande is on a distinguished road
Hello All
I am doing mesh independence study for transient case.Where there is modification of mesh there is sudden shoot in temperature above 5000 k. Can any1 tell me the reason for this?
Thank you....
hiteshlande is offline   Reply With Quote
[ICEM] Problems with export 2D mesh from ICEM to FLUENT newcomer ANSYS Meshing & Geometry 54 September 20, 2014 13:40
I hope you can point out problems in my FLUENT solution tp9180188 FLUENT 2 March 15, 2012 12:40
Convergence issue in Fluent dibs87jg FLUENT 0 April 20, 2011 05:52
Fluent problems with infiniband caludio FLUENT 1 October 9, 2010 05:48
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 17:48
