Two-phase open channel flow
Old   July 6, 2006, 13:11
Default Two-phase open channel flow
Edwin
I could do with some help on this. I'm trying to model flow in an open surface pond. How do I create a gambit model that allows for two-phase flow? The tutorials don't help as they apply an axis of symmetry, which this pond doesn't have. Further, once i get it done, how do i run this model with Fluent? What parameters particularly do i need to look out for? What equation models are recommended if im trying to study the effects of bluff bodies in the flow? I'm experimenting with the k-epsilon equations currently. Thanks guys.
Old   July 6, 2006, 16:54
Default Re: Two-phase open channel flow
greg
try adapt/region/(define regions of phases) go to: initialize/patch (choose adapted region, let say you`ve adapted bottom part of channel so write one for this part of your chanel)
wich model to use ?? It depend if your flow is laminar or turbulent
Old   July 6, 2006, 21:05
Edwin
Thank you very much for your reply. However i'm still not sure how to generate a region to specify the phases. Since i'm modelling a 3-D volume, how do you suggest i define the regions in Gambit before going to the Fluent??Do i create another volume or shall i just seperate the 2 regions with different phases by using a surface??
Thank you.
Old   July 11, 2006, 03:21
draussen
In Gambit you can just seperate your volume and define them as different zones!!! Gambit Zones Command Button - Specify Continuum Command Button! You can name your zones on your own here! During exporting them to fluent, fluent it self names the different zones again with interior! I do not know why, but there is no problem with it!!
boundary conditions in FLUENT VOF for open channel flow newcomer Fluent Multiphase 33 May 28, 2024 14:41
Yacht in Open Channel Flow andreimour FLUENT 1 October 15, 2010 00:54
how to use Up Stream boundary condition in open channel Flow ms.jafarinik FLUENT 0 April 18, 2010 15:38
Open channel flow Mehdi Moayeri FLUENT 0 August 26, 2008 11:55
Open channel flow Walid Main CFD Forum 1 July 31, 2006 01:01
