Natural Convection (Operating Pressure condition)
Old   July 2, 2006, 16:02
Default Natural Convection (Operating Pressure condition)
Andrew Tress
Hi all
I am simulating a closed vesel natural convection problem in Fluent. My task is to check the heat transfer coffecient variation with the change in initial pressure.
There are no inlet or outlet boundary conditions and the only condition impose on the system is isothermal condition on the wall of the vessel and heat generation in the fluid.
I have used Boussinesq approximation for density specification and I need to do transient state analysis.
My problem is when I plot the pressure variation along X dimension of vessel it show almost zero value of pressure (dynamic pressure) in the whole domain even if I set operating pressure as high as 5 bar. I assume I am missing somewhere in specifying the operating pressure condition. Kindly let me know if the experimental pressure condition was 5 bar how should I specify the operating pressure to reproduce the experimental results.
Please help me in the same....
Thanks in advance
Regards. Andrew
Old   July 3, 2006, 19:27
Default Re: Natural Convection (Operating Pressure conditi
Amr
Hi Andrew,
Let me first ask you: why are you interested in the dynamic pressure?. Shouldn't you look for the static value?
Amr
Fluent natural ventilation pressure boundary condition pierresandre FLUENT 24 November 8, 2011 15:32
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 12:35
OPERATING PRESSURE manish FLUENT 6 February 25, 2011 05:40
Help for setting 3D boundary condition in compressing water vapor sogolf FLUENT 0 September 27, 2009 16:05
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
