please help ---mass flow inlet----fluent manual
Old   July 1, 2006, 02:39
Default please help ---mass flow inlet----fluent manual
Mech
Hi I am simulating compressible Nitrogen with ideal gas law. I use mass flow inlet, static pressure, total temperature and outlet pressure. I need to initialize the flow from mass flow inlet. When I initialize from inlet (solution initialization-compute from)then it does not initialize the simulation. It shows me access violation. But Fluent manual section 6.5.1 (defining static pressure) says "if you choose to initialize the flow based on the mass flow inlet conditions, the static pressure will be used in conjuction with the specified stagnation quantities to compute the initial values." So I wonder why it is not working. Can anybody suggest me? Thank. Mech
Mass flow inlet and pressure outlet issue nikhil FLUENT 5 December 11, 2013 13:30
mass flow rate computation in fluent Kishore FLUENT 5 June 27, 2007 04:53
Transient inlet mass flow rate BC HIHI FLUENT 0 May 9, 2006 13:10
Mass flow inlet Anshul FLUENT 2 March 4, 2005 01:19
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 17, 2003 20:23
