June 28, 2006, 20:06 |
File import problem
When I try to import some *.stp (STEP) files into Gambit, I have an error "Translation requires license feature Geom-Trans...Translation failed". Any help regarding this would be appreciated. Thanks all, Regards.
June 28, 2006, 23:13 |
Re: File import problem
you need this Feature in your lincense. it seems you don't have it, which sounds weird, because it supposed to be include in "normal" license (I assume)
July 9, 2006, 19:30 |
This is due to your license. Your license does not have a permit to use 'Geom-trnas' or you didn't install 'Geom-trans'.
Please check your lincese file or reinstall the Gambit.. |
March 29, 2012, 07:15 |
Aydın Dönmez
Rep Power: 14 |
March 29, 2012, 13:53 |
Aydın Dönmez
Rep Power: 14 |
i did it 3 times. its still the same
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
2.0.x on Mac OSX | niklas | OpenFOAM Installation | 74 | March 28, 2012 16:46 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 09:50 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
