Specifying operating temperature in buoyancy flow
Old   June 28, 2006, 05:21
Default Specifying operating temperature in buoyancy flow
PAD
Could someone please explain to me how to specify the operating temperature in buoyant flow using the Boussinesq approximation.
If modelling a long tube with pressure inlet / outlet and a cold tube part in the middle section how should the To value be specified? Same as temperature on pressure inlet or same as temperature on cold wall?
The results will differ depending on which value I choose.
Regards, PAD
Old   June 28, 2006, 12:41
Default Re: Specifying operating temperature in buoyancy f
Evan Rosenbaum
For an open system, the value doesn't matter much. Don't use Boussinesq for a closed system.
Old   June 29, 2006, 02:20
PAD
Hi Evan,
I tried simulating a long vertical tube 0.05 m ID, 1.0 m long. Middle section (0.2 m) was held at 273 K while pressure inlet (top of tube) was held at 293 K / 0 gauge and pressure out (bottom of tube) was held at 293 K / 0 gauge as well.
The results varied dependent on the operating temperature chosen which according to you it shouldn't. Am I doing something wrong?
Thanks in advance!
Regards, PAD
Old   June 29, 2006, 06:45
PAD
Just a thought - would it be possible / useful to make a UDF which applies the Boussinesq approx. locally, i.e. the buoyancy force for a cell is calculated from the mean temperature of the surrounding cells?
Regards, PAD
Old   June 29, 2006, 15:44
Evan Rosenbaum
Well, when I said is shouldn't matter too much, I was thinking in terms of a specific open system with unidirectional flow from inlet to outlet. My error. The situation you describe would be dependent. In an external flow situation (like the outside wall of a building), you would use the ambient temperature for the Boussinesq. In your situation, I'm not sure there is a steady-state solution. The fluid would try to rise in the bottom half of the tube and sink in the top half. You may have an unsteady solution.
operating temperature for water in porous media engahmed FLUENT 0 March 3, 2010 17:21
how to set up high temperature gas turbine flow simulation? adam2008 CFX 1 July 22, 2009 19:33
why is solid temperature same as fluid temperature on flow simulation ? qihongming FloEFD, FloWorks & FloTHERM 0 May 26, 2009 09:57
Stagnation temperature in free molecular flow Anton Lyaskin Main CFD Forum 2 July 30, 2004 10:09
buoyancy driven flow + unsteady co2 FLUENT 4 May 6, 2004 12:37
