problem with nozzle flow
Old   June 27, 2006, 08:12
Default problem with nozzle flow
belinda
I am running a jet through a converging nozzle at Ma=0.5 which enters a domain at atmospheric conditions. The problem is that when i change from first order implicit to second order implicit(segregated solver) the solution (T,p) gets unbounded towards the limits set in the solver. I tried setting the limits to more realistic values than the default but still the problem persists. After a while the solution blows up. I tried both the nita and default versions of the solver.
I use pressure inlet at the nozzle inlet and pressure outlet at the domain exit. Could the problem be due to none reflectiveness of the outlet condition? should the coupled solver give better results?
Thank you for your help and kind answers.
Old   June 27, 2006, 08:39
Default Re: problem with nozzle flow
belinda
Whops, I mean of course *reflictive* boundary condition. I should also add that the residuals look ok until the final blow up. CFL is also restricted under 0.3 . decreasin the underrelaxation did not help either..
Old   June 27, 2006, 09:26
Rams
continue iterating with first order implicit,... for some more iterations,... and then after solution gets stabilized chage to second order implicit,....
reduce under relaxation factor for dentsity etc ,... and crry on
Old   June 27, 2006, 09:36
belinda
thanks for the advice. I tried this already but there was no change in the trend that after some 2000 time steps the solution blows up.
Old   July 2, 2006, 15:08
Radwa
I dont know whats the reflective boundary condition, but did u try using the outlet vent boundary condition
Old   July 12, 2006, 18:42
Dr Hasan Khan
Hello Belinda,
I have solved atleast 100 cases with higher mach numbers for converging/convering-diverging nozzles. Your inlet condition has to be a pressure inlet. Outlet as pressure outlet.
I don't know your geometry exactly, otherwise I would have guided you more.
Cheers hasan.khanCFD@gmail.com
Complex problem: Open Channel Flow lett FLUENT 18 November 10, 2018 19:30
Back Flow problem siddharameshwara OpenFOAM Running, Solving & CFD 7 February 23, 2017 11:02
Convergent-Divergent nozzle problem watto23 Main CFD Forum 2 February 18, 2013 08:01
Con-Div Nozzle Shock structure problem padmanathan FLUENT 2 November 16, 2010 04:37
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
