How to do boundary layer meshing of a 3D diffuser
Old   June 26, 2006, 04:52
Default How to do boundary layer meshing of a 3D diffuser
Durgendra
How to do boundary layer meshing of a 3D diffuser using gambit.which face should be choosen to start the boundary layer meshing thanks
Old   June 26, 2006, 05:00
Default Re: How to do boundary layer meshing of a 3D diffu
Madhukar Rapaka
hi
i think u need the bdry layers only when u define a face with a wall boundary condition. so start the bdry layer from a walll bdry and keep in mind that the mesh shud always be perpendicular or normal to the face. hope this helps. regards
Old   June 27, 2006, 08:46
Durgendra
thanks for ur response I try to create mesh bdry layer along the conical face using following parameters in gambit first layer- .001 first row(a)-5.18e-5 growth factor-1.2 total depth.-0013 no. of rows-10 Internal countinity- yes algorith-uniform trans. pattern- 1:1 trans row- 0 Face- conical face of the diffuser
But i get a trianglular bdry layer mesh at each of plane faces and nothing along conical face.
plz, explain the reason and solution.
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
A question on "Specifying Boundary Layer Deformation Smoothing" didiean FLUENT 2 January 16, 2012 22:39
Meshing cylinders with boundary layer using Gambit Florence ANSYS Meshing & Geometry 5 April 1, 2009 13:36
Inflation layers / boundary layer meshing. andy2o Main CFD Forum 3 February 22, 2009 10:03
Boundary Layer Meshing of a nosecone Chris FLUENT 1 March 15, 2005 13:42
