Turbulence viscosity limited
Old   June 26, 2006, 04:17
Default Turbulence viscosity limited
Madhukar Rapaka
Hi all
i got a warning while runnning a fluent simulation. Turbulent Viscosity limited to viscosity ratio in xx(say 3) cells. with the advice of the group members i have adapted the mesh using Iso values, and carried the simulation for some more iterations. Now the Tubulent Viscosity is limited to viscosity ratio in 1 cell. again i adapted the mesh using iso values and run the simulation. the solution is converged but still i am getting the same warning(Tubulent Viscosity is limited to viscosity ratio in 1 cell).
what shud i do now.... i am clueless ....i am sruggling withis problem for a long time...can anybody help me
thanks in advance
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 15:18
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
turbulence viscosity ratio limited to ........ bbb FLUENT 6 June 10, 2008 08:49
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 07:13
