converting a solidworks file into a fluent file |
June 22, 2006, 15:16 |
i have a geometry made using solidworks,with .sldasm ext. i dont have any solidworks software so i may not be able to save that in any other format..even if there is any option of doing it.i was able to view the geometry using a solidwork viewer which i downlodaded from net.
any suggestion so that i can generate a mesh from that file by may be openning it in some other softwares. or any suggestions which might help me. thank you rahul |
June 23, 2006, 05:11 |
Re: converting a solidworks file into a fluent fil
you should save the file in parasolid (.x_t) format to export it in to Gambit and mesh it. then u can export this mesh file to FLUENT. regards, madhukar
June 23, 2006, 16:04 |
i dont have the solidwork software. i just got the finnished file saved .sldasm . can i change it to parasolid format without solid wotks software.
regards rahul |
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 06:29 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
Converting .geo file into FLUENT | Chie Min | CFX | 0 | May 25, 2001 10:35 |
