Hi all, I have following problem. The geometry is very simple: air enters the pipe from one side under pressure. On the other side there is valve: the valve could be in one of two positions: "closed" where no flow is possible (pipe closed from one side) and "opened" where sucking occurs through the valve. The valve opens and closes periodicaly. I am using UDF to represent changes of the valve state in time but I dont know how to simulated closed valve with pressure BC.
Any ideas? Luk |
Why donīt you change your pressure outlet to wall and backwards ?
Is it possible with UDF? I mean is it possible to periodicaly change type of BC for specified surface/face?
I didnīt work much with UDFīs. But Iīm sure you can handle that with a journal file. The question is how often do you open and close?
About 100/sec. The size of the pipe is few cm in diameter and about 50cm length. Pressures are rather low.
O.K., i tried some things. To change the boundary condition with a journal file is possible. To start the journal file with an execute-comand works too. So there is a posibility to automate the whole thing but itīs a long way.
Maybe someone else knows an alternative. |
Dear Sir, Thanks for Your kind help! I'll try this solution today in few hours.
Luk |
last chance for me to help you is tomorrow, then Iīm on holiday for 2 weeks - Jippie!!!!
The execute comand to start the journal is easy : file read-journal nameofjournal the journal comands to switch from wall to pressure outlet : define boundary-condition modify-zones zone-type ( ID number of your face you want to switch ) pressure-outlet ( or wall when you switch back ) but be careful the settings of your pressure outlet are set to the default values. you can change them with : define boundary-condition pressure-outlet good luck |
#9 |
I wish Your nice holydays! Could You be so kind and send me email for further contact: my address is Lukasz.Czopyk@ifj.edu.pl. I promise not to disturb Your free time anyway.
![]() Luk |
"Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 10:08 |
how to simulate pressure variation wrt time at outlet | gyanesh | FLUENT | 4 | April 21, 2011 03:42 |
How to simulate valve using pressure BC?? | Luk_Fiz | CFX | 4 | August 16, 2010 18:27 |
Does star cd takes reference pressure? | monica | Siemens | 1 | April 19, 2007 11:26 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
