error with ic-cylinder model and parallel processi
Old   June 19, 2006, 09:48
Default error with ic-cylinder model and parallel processi
Jeroen Smits
I am modeling the gas-flow in an internal combustion engine. Because of the amount of cells (800,000) I am working with 2 nodes on a Unix system (parallel processing). After about 40 degrees crank angle I get the following error:
Primitive Error at Node 0: analyze_cell_layer: degenerate cell detected
Error: Compute node encountered error
Error Object: #f
When I check the grid, no errors are found. When I run the same simulation on one node (no Parallel Processing), no errors occur.
Can anybody tell me where this error comes from and what I can do about it? I checked all parameters, but nothing works. I do not think it is an error with the mesh, because on one node no errors occur.
Thanking you in advance, Jeroen Smits
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Parallel Processing ocean wave multiphase model robb CFX 1 July 26, 2010 15:37
Parallel implementation of k-e model Niels Main CFD Forum 6 June 27, 2008 15:31
OpenFOAM 13 Intel quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 13 February 5, 2008 06:26
OpenFOAM 13 AMD quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 1 November 11, 2007 00:23
