need some suggestion
Old   June 14, 2006, 02:21
Default need some suggestion
nabeel
hi, Any body know how perodic boundary condition is made in gambit i have problem in linkinh meshes any help or any tutorial nabeel
Old   June 14, 2006, 10:51
Default Re: need some suggestion
Lee
Can you specify the problem in detail?
Old   June 14, 2006, 13:22
steve
hi,
for example, if you want to define two opposite faces F1 and F2 of a cube as periodic, 1. applying meshing schme for the faces of cube. 2. Then link the faces F1 and F2 by using commands in Face mesh panel. 3. Now apply volume meshing schemefor the cube. 4. In define boundary conditions panel, select faces F1 & F2 and define them as periodic.
This is one of easy way to define periodic boundary conditions. you can also define periodic boundary conditions in FLUENT for non conformal meshes.
hope it helps you!
steve
Old   June 16, 2006, 03:10
nabeel
hi i am just doing a mixer analysis and there i used periodic boundary condition as given in tutorial so i have used symmetry boundary conditions it does not work b/c i not very high force second my volume integral is mush higher than expect any suggestion please tell me
Old   June 27, 2006, 01:36
nabeel
hi i am doing problem in 2d and i linked edges of blades face with outer shroud face edges and set interior boundary conditions in gambit but when i import them in fluent it gives error that then cannot be interior.plz help in this regard
suggestion for thermophysicalproperties for high temperature buoyant flow braennstroem OpenFOAM Running, Solving & CFD 0 March 21, 2011 15:06
any suggestion about method to use? cnmm Main CFD Forum 0 May 29, 2009 00:13
error suggestion llnudt FLUENT 1 November 14, 2006 02:48
Suggestion please newbie FLUENT 0 October 29, 2001 22:28
need suggestion on temperature simulation Bin Li CFX 4 June 23, 2000 03:35
