write profile - journal file
Old   June 13, 2006, 01:25
Default write profile - journal file
mateus
Hi!
I did a unsteady simulation and saved the dat files. Now I want to export the data (velocity on a defined plane) as a text file (or ascii).
How do I write a journal file so that fluent does it automaticly? It must go something like this (write profile command)..
rd/0001.dat file/write-profile/0001/plane-1/x-coordinate/y-coordinate/velocity
rd/0002.dat file/write-profile/0002/plane-1/x-coordinate/y-coordinate/velocity
...and so on.
But when I run journal it doesnt work. I think the problem is when fluent asks to define the second plane but I only want one. What is the text command to "move on" to the next step?
Thanks in advance!
mateus
Old   June 13, 2006, 05:26
Default Re: write profile - journal file
Gernot
as far as I know a return ( for move on ) in the journal-file should be enough to move on. In the text comand line you can check how far the comands are executed correct Open the journal file, go to the comand that is not executed correct and press return. save and try to run again. hope that helps
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 05:26
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 07:43
writing vel. profile with journal file Ralf Schmidt FLUENT 2 January 3, 2006 09:31
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 21:51
