changing units in gambit
Old   June 9, 2006, 14:00
Default changing units in gambit
Brendan
I want to create a geometry in gambit in inches but I cannot find where to change the units. Meters is the only unit that gambit seems to use. How can I change the units to inches?
Old   June 10, 2006, 02:13
Default Re: changing units in gambit
Swarup
Not really necessary. This will be taken care of by Fluent once you read your mesh in Fluent. Do this: create your mesh in Gambit with dimensions in inches say 2 inch by 3 inch. Proportions is all that matters. Now when you read the mesh in Fluent find Grid -> Scale option and in the option "Grid was created in: ", select inches, press Scale and it is done. Your mesh dimensions will be converted into meters (internal unit for Fluent).
Why you need to create mesh only in inches. You can use any dimension. It is a matter of proportions and you should follow consistent units in your mind!
Swarup.
Old   August 13, 2012, 10:12
misagh
misagh is on a distinguished road
Originally Posted by Swarup
;133178
Swarup.
thank you swarup.you solved my problem...
the changes in other parts of fluent should be considered.e.g wall thickness in B.C if the CHANGE UNITS choice has been enabled in the previous step.
so we had better get a summery of B.C before iterations to make sure every thing is ok.report....>summery...>boundary conditions
misagh is offline   Reply With Quote
changing default unit in Gambit NISHIKANT TAMRAKAR FLUENT 6 May 20, 2016 02:22
Units in Gambit........... binubtharayil FLUENT 3 August 18, 2009 05:07
Change Units System in Gambit (microfluidic) djalil FLUENT 0 December 13, 2008 11:53
Changing gambit file without change of case file?? Asghari FLUENT 2 August 28, 2006 14:48
Units GAMBIT VIRGINIE FLUENT 2 November 10, 2005 18:37
