June 9, 2006, 11:18 |
How to Set the velocities of two phases
Hi Fluent Users:‎ I have a stratified two phase (oil-water) flow into a pipe. I was used the two BC ‎velocity inlet and pressure outlet. I have a problem to set the velocity at the inlet to ‎the two phases. So anyone can help me by tell me how can I set the values of these ‎velocities of the two phases from the same inlet? Knowing that I was used the VOF ‎model?‎
Khalid Baker |
June 10, 2006, 02:41 |
Re: How to Set the velocities of two phases
Dear Khalid
The mixture model allows the phases to move at different velocities, using the concept of slip velocities. NOT VOF!! |
Installation problems | indy | OpenFOAM Installation | 7 | April 3, 2009 10:40 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
Problems with installation of OpenFoam | sheyer | OpenFOAM Installation | 8 | July 28, 2008 04:45 |
set up boundary | ritmat | FLUENT | 5 | July 24, 2007 04:38 |
Problem installing on 64bit with ver13 | jonititan | OpenFOAM Installation | 0 | April 28, 2006 06:45 |
