Saving particle (DPM) data to file?
Old   June 9, 2006, 05:35
Default Saving particle (DPM) data to file?
Philip
Hi
I'm running a transient case with a discrete phase model.
I find two ways to write particle data to a file.
1) The first alternative is to use "display/particle-tracks/current-position/write" to file. Then I get data for all particles in the domain.
2) The second alternative is to use "report/discrete-phase/sample/default-interior" Then, as far as I understand when I pick default-interior, I should also get the particle data for all particles in the domain.
However, I will not get the same data in the two files. I get much less data in the second case, why is that? Does it save data in a different way? and do I really get all data when I chose default-interior?
I need to use the second alternative in order to be able to save data continuously during computation, so its important to get it right.
Regards Philip
Old   June 10, 2006, 07:54
Default Re: Saving particle (DPM) data to file?
adriano
I think is better to use a UDF to define your output format in case 2).
Try to have a look to UDF Manual or say as which are your particle tracking values.
Regards.
Adriano
Old   June 12, 2006, 02:41
Philip
Thanks Adriano I did write a UDF. But the thing is that, even if I write a UDF-output file I still only reach the particles in the specified surfaces which I pick, default-interior here, and I'm still not able to reach all particles in the domain.
If you or anyone else know how to reach all particles, it would be a great help for me.
Philip
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 09:33
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 21:51
