long tube mesh
Old   June 8, 2006, 05:23
Default long tube mesh
asghari
Hi all, Please tell me , what is best method for grid generation in very long tubes? Thank all. Best regards.
Old   June 8, 2006, 10:13
Default Re: long tube mesh
Siddharth Khowala
hi for long tubes mesh generation through gambit would be sufficient . I have meshed tubes having aspect ratios of 100-300 using gambit.Also for mesh generation near the walls you can make the regions finer using ratios or double ratios(if ur are not using symmetry).
regards
Old   June 8, 2006, 13:49
ck1973
See this web page : http://instruct1.cit.cornell.edu/courses/fluent/
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 06:25
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[snappyHexMesh] non-smooth mesh Svensson OpenFOAM Meshing & Mesh Conversion 11 January 18, 2012 10:13
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
