mesh quality: urgent
Old   June 8, 2006, 03:51
Default mesh quality: urgent
Madhukar Rapaka
hi
i am generating a mesh in Gambit. I would like to know abt the qulity of the mesh. when i am checking the quality of the mesh: the worst element has a value of 0.80176, and the no. elements in the range 07 to 0.9 are 70. Is the mesh quality good or ????. If the quality is not good...what i have to do(to improve the quality).
thanks in advance
Old   June 8, 2006, 10:09
Default Re: mesh quality: urgent
Siddharth Khowala
hi As per the mesh quality i cannot comment best for you would be to read the mesh file in fluent and check the mesh.To improve your mesh quality in gambit it is best to divide your region into smaller volumes and mesh them depending on the regions of interest to be meshed appropriately(coarse or fine).I have done this myself hence would advise you to try it,this also reduces the number of skewed elements.
Personally as far as i think your mesh quality does not look bad but maybe you should wait for some comments from other forum members
regards
Old   June 8, 2006, 10:43
Gernot
A good mesh quality is not only defined by the skewnes. You should also check the edge ratio.
[ICEM] Low quality Tet prism mesh saisanthoshm88 ANSYS Meshing & Geometry 17 September 28, 2016 17:50
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[ICEM] trouble with mesh quality from ICEM in CFX Solver escher25 ANSYS Meshing & Geometry 0 February 28, 2011 08:38
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
