multiphase model & separation
Old   June 7, 2006, 13:08
Default multiphase model & separation
naser
Hi every body
Actually my model is a horizontal pipe with oil/water flow.
If it is possible, I would like to directing me which model should I use: VOF, multiphase, or eulerian such that I got the two pahses are seprated; water is down and oil is above due to their densties?
Is there any one have did similar model before and can direct me?
Best Regards, Naser
Old   June 7, 2006, 18:02
Default Re: multiphase model & separation
siao fei
i think using Eulerian is a good choice. however, patch the pipe first for the water and oil level before u start simulating, to make sure the level is separated. it is kinda difficult to run the simulation without patching, and wait for the separation due to their density and gravity.
Old   June 7, 2006, 19:30
naser
Thank you siao for your kind reply.
What do you mean by "patching"?
Old   June 7, 2006, 20:45
Maciej
patching is second, optional step of initialisation. First you initialize whole volume to contain e.g. water and then you patch the upper part with lighter oil phase. So you have to make Adapt/Region - that region, when you create it (Mark), will be accesible in the panel Solve/Initialize/Patch.
Old   June 8, 2006, 05:08
naser
Thanks Maciej
Still I think It's bettere if I got a tutorial for simulating a model similar to mine...any one can help??
Old   June 9, 2006, 07:12
kotan
How can we initialize volume fraction for annular flow?
initialize and patch is not good way for annular flow.
thanks already for your answers
Multiphase model in Fuel Cell module E-Font FLUENT 0 March 9, 2011 15:44
Multiphase and Radiation Model in Fluent LucioBP FLUENT 0 January 30, 2011 15:41
Which Multiphase Model i can use? saiburry ANSYS 1 December 3, 2010 21:19
Parallel Processing ocean wave multiphase model robb CFX 1 July 26, 2010 15:37
multiphase model and drag law Yasmail AKARIOUH FLUENT 0 April 29, 2008 08:44
