UDF for VOF interface moving with velocity V
Old   June 6, 2006, 05:22
Default UDF for VOF interface moving with velocity V
Johann
Hi all Fleunt suers , please can some body help me on the case of moving interface between 2 phases on VOF model , I need to specify the deplacement of the inteface at velocity V (mm/s) using udf .. (the depalcment is perpendicular to this interface)
thanks in advance Johann
Old   June 9, 2006, 12:15
Default Re: UDF for VOF interface moving with velocity V
shanti
Hi Johann
At the interface you will have the volume fraction in the range of 0-1. So you can write a loop and say for those cells have a velocity in the y-direction .
Hope it helps Shanti
Old   June 10, 2006, 05:27
Johann
Hi Shanti, thanks for your reply , But I still have prblem , what kind of macro should i use to set a velocity to to the interfac cells (0-1 volume fraction ) .Should I use A momentum source (DEFINE_SOURCE) ? please help me thanks Johann
Old   June 10, 2006, 05:42
Johann
Dear Shanti...please can you email me some example from Fluentusers.com related to that prblem and to the volumetric heat source variation with time .. here is my email adress amine_137@hotmail.fr (unfortunately I dont have login password ) thanks
please help UDF for velocity profile in y-directio raju Fluent UDF and Scheme Programming 6 April 13, 2019 00:21
UDF for velocity farne FLUENT 1 February 25, 2009 01:29
UDF velocity and temperature Raj FLUENT 3 February 1, 2009 19:29
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
