Euler-Euler heterogeneous reaction rate?
Old   June 5, 2006, 10:30
Default Euler-Euler heterogeneous reaction rate?
HP
Hi users! I am trying to define the reaction rate of a heterogeneous reaction in an Euler-Euler approach with the UDF macro DEFINE_HET_RXN_RATE. The problem concerns solid particles which react with the surrounding gas. Which should be the units of the calculated r-r? Perhaps something like [Kgmol solids/m3 mixture - s]?
Thank you for your help!
HP
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 17:55
multiphase heterogeneous reaction definition coalgas FLUENT 0 February 9, 2010 03:05
surface reaction rate with udf yellow-stuff FLUENT 4 January 29, 2010 13:53
UDF changing the rate exponent of a reaction Stefan H Fluent UDF and Scheme Programming 0 September 16, 2009 14:20
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
