3D shell and tube heat exchanger
Old   June 5, 2006, 07:34
Default 3D shell and tube heat exchanger
Peter Jansen
My final proyect is about a shell and tube CFD. I need to obtain pressure drop and eficience results. My first task is develope the mesh. The hot fluid is gas and the coolant is water. I want to mesh the tubes too. I would like to receive some advices about the mesh. Boundary layer is a important point but i wouldnt like to increase too much number of cells. In Fluent...what turbulent model should i use? what about 1rs or 2nd order in discretization scheme? I have done some meshes and i get good results in pressure but results in temperature aren't good enough. Thanks in advance
Old   June 5, 2006, 15:51
Default Re: 3D shell and tube heat exchanger
Ben Lamek
Do not use tetrahedral mesh in fluent for dual heat transfer (sold/fluid) results are no good according to heat exchanger conference. Do not forget to take in account buoyancy.
B.L.
Old   June 7, 2006, 08:01
Peter Jansen
Thanks for your answer. My geometry is really complex. What about a layer of prims in the heat transfer surfaces? how can i take in account the buoyancy in fluent?(i'm novice ni Fluent). I had thought about make velocity & pressure gradient adaption.
Thanks in advance for your suggestions.
P.J.
Shell-and-tube heat exchanger Andytzki FLUENT 0 February 14, 2011 16:22
FSI error ERROR #001100279(Shell & Tube heat exchanger) Chandrashekhar CFX 3 March 26, 2010 16:04
Heat exchanger modelling Diana FLUENT 5 February 24, 2010 19:02
Heat Exchanger Model - urgent JSM FLUENT 6 September 22, 2007 05:25
How to simulate 3D shell and Tube heat Exchanger san FLUENT 2 February 22, 2006 06:44
