floating point error when starting to iterate
Old   June 1, 2006, 13:37
Default floating point error when starting to iterate
Ralf Schmidt
Hi!
I know, there is a lot of discussion about the floating point error, and there are a lot of answers.
But, I can not find a sollution to my problem:
I have a 3D geometry with about 1.000.000 cells. It is incompressible, air. I tried all solvers, but every time the same: The floating point error comes when I am starting to iterate. Not even the first iteration can be done...
I tryed different urf, different courant numbers and different discretisation...
Any idea??
Ralf
Old   June 2, 2006, 07:00
Default Re: floating point error when starting to iterate
Raza Javed
It might be due to your low computer memory(RAM). Try to reduce the grid about 500000 cells and see does it works or not.
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 22:51
MPI Error - simpleFoam - Floating Point Exception scott OpenFOAM Running, Solving & CFD 3 April 13, 2012 17:34
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 05:59
reactingFoam floating point exception pajofego OpenFOAM 0 November 6, 2010 18:29
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
