meshing a parasolid import in gambit
Old   May 31, 2006, 05:13
Default meshing a parasolid import in gambit
Madhukar Rapaka
I am modelling a flow thru a cylindrical reactor. (the reactor consists of a horizontal circular cylinder, which contains again cylindrical inlet and outlet mounted on the circular face of the cylinder. The circular cylinder also consists of 3 baffle plates inside)I drew the geometry in solidworks and imported it into Gambit(bcos of the complex geometry of the baffle plates). As the geometry is very complex, i am a little bit confused from where to start meshing the geometry. Can anybody help me. If u want to see the geometry i can send it.
any sort of help is greatly appreciated, thank you
Old   May 31, 2006, 07:03
Default Re: meshing a parasolid import in gambit
Rajat Deshpande
hii i am a student @ iitb can u send the geometery to me .. i cud have a look at it
Old   May 31, 2006, 08:02
Madhukar Rapaka
Hi Rajat
can u give me ur mail id.... mine is madhukarrapaka@yahoo.com
regards
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 06:22
meshing a fan using gambit tony FLUENT 1 February 15, 2008 01:28
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Gambit: too long meshing time! delsolman FLUENT 1 January 29, 2008 20:06
