display contours every time urgent
Old   May 30, 2006, 17:33
Default display contours every time urgent
sandra
i want to display contours of velocity at any time 5s,10s...... how to this sandra
Old   May 30, 2006, 20:39
Default Re: display contours every time urgent
HAR
I suppose that you are using unsteady condition. Then, before starting interating, you need to set up the animation options, in which you select the variable that you want (p.e Velocity or Volume fraction) as well as the time interval. Finally, you run and every time step fluent saves the image. However, be carefully about the hard disk capacity.
I hope this help you.
Humberto
Old   May 31, 2006, 05:38
sandra
can you explain me more and give me step by step procedure
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 10:20
PostChannel maka OpenFOAM Post-Processing 5 July 22, 2009 10:15
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 13:32
