Volume Fraction vs Velocity????
Old   May 30, 2006, 17:07
Default Volume Fraction vs Velocity????
HAR
Hello, I've been working with a model of a tank in which water is coming in from the top and getting out trough a pipe.
When I plot the contourn of volume fraction of water, it shows me that the pipe is partially full because the vf of water is zero at about 30% of the pipe's diameter. However, when I plot the contourn of velocity magnitude, it shows me that the pipe is full becouse I have velocity values around the whole diameter. If the volume fraction is zero at any point, how the velocity of that fluid can be more then zero?
Please, tell me any comment or suggestion about it.
I will appreciate your help.
As information: - Inlet BC: Vel.Inlet - Outlet BC:Pressure Outlet - Top of the tank BC: Pressure Outlet
Thanks a lot
Humberto
Old   May 30, 2006, 17:19
Default Re: Volume Fraction vs Velocity????
chankhar
mr humberto ,tell me yes if you work with a simulation of tundish chankhar
Old   May 30, 2006, 17:30
HAR
No, I'm not working on it.
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
Difference between Volume Fraction and Mass Fraction in CEL foo7 CFX 0 September 21, 2011 09:45
interDyMFoam - change in volume fraction gopala OpenFOAM Running, Solving & CFD 0 April 27, 2009 11:46
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
the Eulerian model and the lower volume fraction hx li FLUENT 2 October 27, 2005 07:17
