create new material
Old   May 29, 2006, 16:13
Default create new material
charlotte
i want how to create a new material, i want the procedure step by step charlotte
Old   May 30, 2006, 05:05
Default Re: create new material
Steve Silvester
Go to the menu 'Define>Materials' then just fill out the boxes, give it a name, set the material type (fluid/solid), set the density, viscosity and thermal properties if required. Then click Change/Create, it'll give you an option to overwrite the existing material or not. That's about it really. Check the materials database though, the material you require might already be there.
Regards
Steve
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
[blockMesh] Include list of points Hikachu OpenFOAM Meshing & Mesh Conversion 0 June 20, 2011 10:03
Actuator disk model audrich FLUENT 0 September 21, 2009 08:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 02:07
