May 29, 2006, 13:14 |
define profile UDF
hi. In Fluent we can define species mass fraction by DEFINE_PROFILE UDF. How to do that if only arguments are D_P (name, t ,i) where "t" is tread and "i" is index of variable. I`ve found in UDF user giude that species mass fraction or mass flux can be described or changed by DEFINE_PROFILE. How?? I need to specify y[i], x[i], mixture_c, and than function = y[i]/(y[i]+x[i]). Can you help me with it? Thanks for time.
June 3, 2006, 04:44 |
Re: define profile UDF
HI I want to define a face motion by "define\profile". How can I do this. Does it need C compiler for "profile" such as UDF. when I write profile file for face motion, the following error apears: Error: eval: unbound variable Error Object: name
your help will be highly appreciated. |
UDF error - parabolic velocity profile - 3D turbine | Zaqie | Fluent UDF and Scheme Programming | 9 | June 25, 2016 20:08 |
How to use UDF to define a moving wall | lingo | FLUENT | 9 | August 19, 2014 10:14 |
defining temperature profile with UDF | mohammadkm | Fluent UDF and Scheme Programming | 11 | July 3, 2013 01:15 |
Pressure profile UDF for unsteady-state problem? | Mohsen Keshavarzian | FLUENT | 2 | August 20, 2008 05:22 |
UDF update profile | ramesh | FLUENT | 0 | June 29, 2003 15:14 |
