May 27, 2006, 05:19 |
v2f Turbulence model - how to enable it?
Iam a research student in IIT Madras, India. Our institute has purchased license for v2f turbulence model. But it seems that our people dont knw how to enable it in the fluent menu. I need help in enabling it. In fluent documentation it was mentioned that after purchasing the module, a scheme command must be used to enable it. I am not clear in this regard. please clarify. Thanks in advance Kulasekharan |
May 27, 2006, 08:04 |
Re: v2f Turbulence model - how to enable it?
May 27, 2006, 15:29 |
what is the v2f model ,can you explain me i want to help you chankhar
May 28, 2006, 02:07 |
Read V2f as "V-square f" model. a turbulence model, (hope u knw what turbulence is and modeling of turbulence) which works along with k and e equations to predict the near wall turbulence better
May 28, 2006, 02:09 |
i have seen this in the fluent help.
where exactly to use this command. can u eloborate more on the step by step procedure, please. |
May 28, 2006, 02:18 |
just type all the command in the command line, then 'enter'. command line mean after '>' in fluent.
good luck! |
May 28, 2006, 03:39 |
yeah.. it works... thanks a lot friend !!!
Modified k-e turbulence model UDF | Travis | Fluent UDF and Scheme Programming | 7 | November 11, 2018 21:21 |
V2F Turbulence model | morteza08 | FLUENT | 3 | February 13, 2011 08:36 |
v2f Turbulence Model (and others?) | Travis | FLUENT | 4 | January 7, 2009 02:18 |
v2-f turbulence model in CFX? | flga | CFX | 14 | November 23, 2006 07:12 |
Turbulence model | Herry | Phoenics | 1 | May 29, 2003 14:19 |
