How to compiled on windows system.
Old   May 25, 2006, 16:52
Default How to compiled on windows system.
AdN
I use UDF for my calcul, so to use my function in Fluent, I interpret my .c . But I try now to compile my function instead of interpret. But I don't succeed. I'm in a windows system, I have visual C++ installed in my system. But when i tryed to compiled, Fluent send me an error message. If someone can help me to trim my problem I will be greatful. Thanx you
Old   May 25, 2006, 21:13
Default Re: How to compiled on windows system.
Shanti
Hi
Try starting FLUENT from the dot prompt instead of starting it by clicking icon.
Hope it helps... shanti
Old   May 26, 2006, 05:27
AdN
Thank you!
I try to do this, but when I compiled my function, fluent tell me that nmake file is not reconise as an internal command or an external command or a command file. Where is the problem? Can you help me pease. Thank you very much for taking time to response me.
Old   May 26, 2006, 10:58
Shanti
Do you have nmake.exe in the FLUENT working folder? Try it, i also dont know exactly. Shanti
Old   May 26, 2006, 13:20
Allan Walsh
You need to set up path and environment variables. Either look at Fluent documents or else look at past postings in this forum for the details.
The different UDF rules between linux system and windows system TURNER GE Main CFD Forum 0 September 6, 2011 06:13
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
Linux to Windows (dual boot system) Alex Main CFD Forum 9 May 3, 2007 04:36
windows operating system scientist Main CFD Forum 8 November 19, 2004 04:30
Compiled UDF in Windows XP CP FLUENT 1 August 7, 2003 12:50
