May 24, 2006, 16:55 |
Interesting problem
Hello everybody
I am trying to solve a 2D axisymmetric problem of heat transfer corresponding to an annulus. I have all the four edges defined as walls, the left one with a constant heat flux, the right one with a constant temperature (=298 K), the top and bottom as insulated. The problem is that once I run the solver and post process my results, I see that the tempeature on the right edge is not equal to 298K as it should be. It gives me something close, like 299K or 300K but not what I impose on it. Please let me know as to why this is happening. What should I do to overcome this problem?? Thanks |
May 27, 2006, 15:24 |
Re: Interesting problem
the walls are adiabatic or no chankhar
Problem with interFoam; Wave/wiggle alpha1 behavior | JonW | OpenFOAM | 10 | February 4, 2023 08:27 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 05:43 |
Problem in implementing cht | tilek | CFX | 3 | May 8, 2011 09:39 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
extremely simple problem... can you solve it properly? | Mikhail | Main CFD Forum | 40 | September 9, 1999 10:11 |
