exporting surface/line of a case file to other cas
Old   May 24, 2006, 00:42
Default exporting surface/line of a case file to other cas
Mazyar
Thanks for your interest in reading my question.
I have already defined many LINES in my domain in order to extract the data on these lines. I have similar case files that I need to define the same LINES. It is very time consuming to define those lines in each case file. I was wondering if there is any way that I can copy or export the lines from the proginal file to the others.
Thanks, Maz
Old   May 24, 2006, 01:40
Default Re: exporting surface/line of a case file to other
Peter
If you're prepared to do this just one more time, there is a way out. Just before creating the lines/surfaces, start the journal from the file menu and when you're done, stop the journal. Now, you can use this journal file to create lines/surfaces in other cases with least effort.
Old   May 24, 2006, 02:08
Mazyar
Wondeful, it worked as you said; it will save me lots of time. Thanks lot Peter.
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 07:29
Convection discretization schemes for LES sek OpenFOAM Running, Solving & CFD 38 July 31, 2017 15:30
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
