UDF:DEFINE_DPM_BC(AD_SCAF,p,t,f,f_normal,dim)
Old   May 23, 2006, 16:04
Default UDF:DEFINE_DPM_BC(AD_SCAF,p,t,f,f_normal,dim)
Adriano
hI, with this little UDF I have to impose this simple BC to a Porous Jump interior surface: 1 - if particle identity is equal to selected number, trap particle; else 2 - apply the 'interior' attribute to my surface, so continue with tracking particle.
the problem is: in case 2 - particles stop their run! It is wrong!!!!! Sigh please any suggestions?!? I'll be crazy very soon!
Many thanx to helper!!
Cheers Adriano
ps: this is the code.
DEFINE_DPM_BC(ADESIONE_SCAF,p,t,f,f_normal,dim)
int select,l;
FILE *fp;
/*TO call function that makes the comparison */
select=confronta(p->part_id, a);
if (select==1)
Message("select = %d part_id ferma = %d\n",select,p->part_id);
fp=fopen("ADESIONE_SCAF.txt","w");
fprintf(fp,"((%10.6g %10.6g %10.6g %10d %10d %10.6g %10.6g %10.6g) %d)\n",p->state.pos[0],p->state.pos[1],p->state.pos[2],t,f,f_normal[0],f_normal[1],f_normal[2],p->part_id);
fclose(fp);
Trap_Particle(p);
l=PATH_ABORT;
if (select==0)
l=PATH_ACTIVE;
return l;
Old   April 25, 2017, 04:12
Yoon
touyet is on a distinguished road
I stuck on this problem..
Did you get any answer of it??
touyet is offline   Reply With Quote
Old   April 26, 2017, 03:03
ctw987 is on a distinguished road
hi touyet!
you stuck on that problem?
i got answer! plz call me now
ctw987 is offline   Reply With Quote
Old   August 9, 2018, 03:08
Default have you solved the problem?
hxw
jackstraw is on a distinguished road
Originally Posted by ctw987 View Post
hi touyet!
please share your code. Thanks a lot
jackstraw is offline   Reply With Quote
