Outlet Boundary Condition
Old   May 22, 2006, 08:32
Default Outlet Boundary Condition
Tang Kuei
I am simulate with fluid fow in a channel with a heat source. I would like to set the Inlet and Outlet temperature with room temperautre. I choose the Pressure_Inlet and Pressure_Outlet, respectively.
After the convergence reached, the temperature at Outlet is higher than room temperature. What's wrong with my boundary?
Old   May 22, 2006, 18:18
Default Re: Outlet Boundary Condition
schimek
You said you had a heat source in your model. If the inlet flow has room temperature and there is heat added to the flow then the temeperature will increase.
Outlet Pressure-flow coupled boundary condition (Windkessel) cfdfsi Fluent UDF and Scheme Programming 3 July 21, 2017 13:30
Boundary Condition outlet natantyt FLUENT 0 September 27, 2010 16:30
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
inlet and outlet boundary condition for turbomachinery solution siamak1424 OpenFOAM 2 August 15, 2009 12:14
Outlet boundary condition CN FLUENT 6 May 22, 2005 10:37
