May 22, 2006, 00:48 |
access drag coeff and udf for granular temp
Hello, Does any body know how to access drag coefficient in Eulerian granular model, I find a Macro C_DRAG_COEFF_IJ(c,t,i,j),but i didn't know what is the meaning of i and j,and how to set it?
another problem is about UDF for granular temperature in Eulerian model,i write a UDF to test it,which is given below,but when i use display\contours\granular temperature, the reported granular temperature is 0.1 for all cells,Could somebody tell me what wrong in my UDF? thank you in advance!! jwwang DEFINE_PROPERTY(granular_temperature,c,t) { real granular_tem; granular_tem=0.555; Message ("granular_tem=%f\n", granular_tem); return granular_tem; } |
UDF: CONTROL DRAG/EXCHANGE COEFF | Luis | Fluent UDF and Scheme Programming | 4 | July 16, 2012 06:27 |
UDF for heat transfer coeff.. | ravi | FLUENT | 2 | July 9, 2004 00:09 |
