How to represent two phase flow in Gambit
Old   May 21, 2006, 01:21
Default How to represent two phase flow in Gambit
K.Baker
Hi ‎ How I can represent two phase (air-water) flow in a pipe using gambit in which the air ‎layer be flow over the water layer and there is interface between the two phases. ‎Anyone Kindly assist me in this problem? Thanks K.Baker
Old   May 21, 2006, 03:08
Default Re: How to represent two phase flow in Gambit
Mac
You do this in the VOF model when you use Fluent. Not in Gambit. It appears that you have serious trouble in multiphase CFD basics. I'd recommend reading some classic journal articles on simulating multiphase flow using CFD.
Old   May 21, 2006, 11:21
K.Baker
Can you tell me to how can I define two phase (air-water) flow entering pipe with ‎different velocities using the VOF model.‎ Can you also send me any solved example in this problem. Many Thanks K.Baker
Old   May 21, 2006, 21:09
Mac
Please check section 24.2.9 (Open Channel Flow) in the manual.
Old   May 22, 2006, 09:03
K.Baker
I am not found this section in the manual and I think the reason due to that I used Fluent ‎‎5 and may its manual did not contain this section can you please send me this section by ‎my email khalidb77@yahoo.co.uk. Thanks a lot Khalid Baker
behavior of two phase flow in a pipe Sonia84 FLUENT 5 September 17, 2013 17:31
how 2 freeze 1 phase flow field & start lagrangian KK CFX 5 February 14, 2008 17:48
low speed compressible two phase flow?? cat CFX 0 November 15, 2005 08:59
LES on two phase flow Li Yang Main CFD Forum 0 May 12, 2004 09:10
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
