look-up table for wet steam
Old   May 18, 2006, 07:26
Default look-up table for wet steam
Jiri Novak
Hi folks!
i have a question from turbomachinery. I need help with setting wet steam properties by means of look-up tables providing discrete values for certain property interval instead of demanding analytical computation. Each table (usually this three : T(p,h), v(p,h), S(p,h)) is based on 2D diagram, and provides fitting value from closest interval by suitable UDF. During the CFD computation, the values are alocated in the memory or simply in the text file. I want to write the UDF for this problem. Does anyone know how to do this and can offer any help?
Old   June 2, 2006, 02:45
Default Re: look-up table for wet steam
Sam
Try this link
http://www.lulu.com/content/278487
It has concise steam tables that can be looked up free for both wet steam and saturated steam
Old   August 12, 2010, 05:49
Default wet steam udf
maryam
salam is on a distinguished road
hello everyone,
can I use srk eos as udf with "wet steam" model for a high pressure real gas?
thanks alot
salam is offline   Reply With Quote
Old   August 12, 2010, 06:02
Default wet steam model
maryam
hello everyone,
I have a real gas contains vapor water as my material that in my model water condensation will occur. please tell me if i can use the "wet steam" model in my simulation. if yes, can I use the srk eos as udf with wet steam model because the pressure in my work is very high.
thanks a lot
How to simulate steam cavitation event CFX JRL4444 Main CFD Forum 2 February 13, 2009 14:33
Use of table of steam properties Ermanno CFX 0 October 16, 2006 02:50
Table Manipulation furkan Siemens 0 April 4, 2006 11:23
L:ooking for Steam Table Noora Main CFD Forum 0 October 4, 2004 00:58
steam properties rendra Main CFD Forum 5 April 13, 2000 05:05
