COMSOL or Fluent ?
Old   May 16, 2006, 18:29
Default COMSOL or Fluent ?
siao fei
Hi everyone,
I am new with CFD analysis. I have a few questions about COMSOL and Fluent:
1) What is the difference between COMSOL and Fluent. Do they have the same function?
2) In your opinion, which program will be better for oil and gas industry. ie, i need to deal with sloshing model and flow model.
Thanks in advance for your advice.
siao fei
Old   May 17, 2006, 15:55
Default Re: COMSOL or Fluent ?
Astrid
Forget COMSOL. This is easy to use for small problems (academic, 2D, etc) but not for realistic cases. You should either consider one of the large suppliers like ANSYS-CFX, Fluent, StarCD.......
Astrid
Old   May 17, 2006, 21:56
Mac
I agree. If you're more in the 'Open source'[1] or more rigorously 'Free software'[2] spirit, I would highly recommend using OpenFoam[3]. I've been a Fluent user for about 3 years now, and I'm making the transition to OpenFoam simply because it offers me more freedom to tweak every aspect in detail.
[1] http://www.opensource.org/ [2] http://www.gnu.org/philosophy/free-s...r-freedom.html [3] http://www.opencfd.co.uk/openfoam/index.html
Old   May 18, 2006, 17:55
Ze
Is openfoam a software to simulate foam and foaming flows?
Old   May 18, 2006, 22:09
Mac
No. If you read the webpage correctly, you'll see that it is a general purpose CFD code that can even do DNS if you want. It has most capabilities already. Interface tracking VOF, Eulerian bubbly flows, etc. etc.
Old   August 30, 2011, 00:44
Reza
rk_k67 is on a distinguished road
Hi MAC ,
I dont know any thing about C++ (which openfoam is based ) . I want to use the VOF level set method . Do I need to learn C++ in order to use openfoam ? or is it just as like using commercial codes with no GUI ?
Cheers
Reza
rk_k67 is offline   Reply With Quote
Old   August 30, 2011, 07:55
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
if you don't want to developp your own solver, you don't need to learn C++.
Just use solvers which are already available.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 04:34
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 21:23
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 12:55
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 17:41
COMSOL or Fluent ? siao fei Main CFD Forum 0 May 16, 2006 16:07
