boundary condition of face for liquid and gas
Old   May 16, 2006, 13:27
Default boundary condition of face for liquid and gas
Luke
Hellow I have a container filled with water. The water surface is exposed to the air. The container has a heat generation in it, so the water will be heated. But the thermo flow in water surface need to be convected to the air. I do not know how to set this boundary condition. How can I set the boundary condition for the water surface.
Can somebody help me? Thx.
Old   May 18, 2006, 04:23
Default Re: boundary condition of face for liquid and gas
Bagus Putra Muljadi
I think you can try to set the boundary condition to INTERIOR adjacent to air surface. But in that boundary, you will have to use only 1 face used together by two continuum ( air and water )or else you find another difficulty to match the face meshing.
Or you may try to use INTERFACE but you will have to stitch the adjacent faces.
I'd rather to use INTERIOR than INTERFACE.
good luck
Old   May 18, 2006, 08:23
Luke
Thank you for your reply. If I use boundary condition to INTERIOR for air and water face, does the external air grid need to be establish ? I now establish only the water container grid (or mesh). Can I set boundary condition for water face which has the effect of the external air convection without establishing the air grid.
I once use the " WALL " boundary condition for water face boundary and it can set the thermal condition to " CONVECTION " which can set the " HEAT TRANSFER COEFFICIENT " and " FREE STREAM TEMPERATURE ". I ever think it is the outside convection heat transfer coefficient and outside temperature. Am I wrong?
Old   May 18, 2006, 12:34
Bagus Putra Muljadi
Basically, every continuums in fluent ( either it's liquid or gas ) have to be defined ( converted into grids ) if you want to observe their property distribution. Temperature, Pressure, velocity or any other properties will be observed using infinite element method as nodes in FLUENT. Unless you only interested in monitoring the liquid properties.
If you use WALL as the boundary condition, FLUENT will assume that fluid velocity adjacent to the wall is zero. I think It will be like you have a thin layer between the liquid and the gas.
I hope it helps
Bagus Putra Muljadi
Old   May 19, 2006, 03:37
Luke
Thx for your reply~ I do not want to research the gas distribution. I just hope that I can simulate the water temperature decreased through the water face to the outside gas (PS: The water temperature is higher than outside gas)
I do not want to establish gas grid and just hope the water face has the convection effect (out of my container). Does any boundary type or setting skill can handle it?
Thank you !
Old   May 19, 2006, 04:05
Bagus Putra Muljadi
If that so, it is possible I guess to just use WALL as you boundary surface condition.
You can set the wall's temperature and heat coefficient factor. Theoritically this condition is incorrect , but if the wall is assumed to be very thin I think the calculation will still valid.
You can moreover set whether the solving model is steady or unsteady.
hope this helps regards bagus putra muljadi
Old   May 21, 2006, 14:45
Luke
THX Now I can run out the results and it seems to have the convection on the water face. But I can not confirm the results to be corrent. I will check it seriously.
Thank your for your answers again~
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Pressure boundary condition and real gas Pifou FLUENT 0 July 19, 2005 12:42
